  • Consolidated 14 AWG 3C Portable AC Power Cable SJOOW 250 ft.
CLEARANCE Consolidated 14 AWG 3C Portable AC Power Cable SJOOW 250 ft.
ConsolidatedPart # 101-616
This SJOOW heavy duty power cable is very flexible and water resistant making it suitable for a variety of indoor/outdoor uses. Make or replace damaged AC cords with this 14/3 thick SJOOW jacked power cable.
  • 41/30 AWG ASTM B-174 and UL62 stranded bare copper for best conductivity and flexibility
  • Oil, weather, sunlight, and water resistant for a variety of applications including outdoor use
  • Black neoprene thick jacket with temperature range from -40° to 194° F (-40° to 90° C) 300V
  • UL and CSA approved
We'll send you an email when Consolidated 14 AWG 3C Portable AC Power Cable SJOOW 250 ft. is back in stock or available for preorder.
This heavy duty power cable is very flexible making it suitable for a variety of indoor/outdoor uses. Make or replace damaged AC cords with this 14/3 thick SJOOW jacked power cable. Premium grade black rubber jacket allows good flexibility even in low temperatures.
Specifications: • Temperature range: -40° to 194° F (-40° to +90° C) • Voltage rating: 300 volts • Wire type: 14/3 41/30 AWG stranded bare copper B-174 and UL62 with SJOOW jacket • Insulation: EPDM • Jacket thickness: 0.03" (0.8mm) • Nom. O.D. 0.36" (9.144mm) • Approvals: VW-1 FT2 RoHS and MSHA, UL and CSA • Conductor colors: Black, white, and green • Made in Poland.
BrandConsolidated
Part Number101-616
UPC848864067599
Weight29.1
Cable RatingSJOOW
Conductors3 Conductor
Jacket ColorBlack
Wire Gauge14
