  • Coax/Stranded Large Gauge Wire Cutter with Wire Stripper 14-8 AWG
CLEARANCE Coax/Stranded Large Gauge Wire Cutter with Wire Stripper 14-8 AWG
Parts ExpressPart # 360-625
Cut and strip coax and large gauge wire with this 2-in-1 tool. Its curved jaws makes it easier to cut through these larger cables.
  • Curved jaws prevent larger cables from squirting out during the cutting process
  • Built-in wire stripper for 14 to 8 AWG wires
  • Rubber coated handles for comfort
CLEARANCE $2.50
MSRP: $9.99
Save $7.49 (75%)
346 In Stock
We'll send you an email when Coax/Stranded Large Gauge Wire Cutter with Wire Stripper 14-8 AWG is back in stock or available for preorder.
Cut and strip coaxial and large gauge wire with this 2-in-1 tool. Its curved jaws prevents the larger gauge wires from squirting out during the cutting process. Remove the wire's insulator with the convenient 14 to 8 AWG wire stripper. The rubber coated handles enable you to add more pressure to the cutting process without hurting your hands.
Part Number360-625
UPC848864070766
Weight0.47
