  • Clark Synthesis AQP140 Aquasonic Isolation Transformer
Clark SynthesisPart # 300-878
Model: AQP140
This Aquasonic Isolation Transformer is needed to completely isolate the Diluvio Underwater Loudspeaker from your amplifier to protect against potential power issues. This transformer is housed in a weatherproof box and includes 2 Neutrik Speakon connectors.
  • Protects both the Diluvio Underwater Speaker and amplifier
  • Includes two Neutrik Speakon connectors for wire connections
  • Simple design, just mount and then plug in the speaker and amplifier
  • Housed in a weatherproof box with included mounting tabs
Your Price: $299.95
Only 2 In Stock
We'll send you an email when Clark Synthesis AQP140 Aquasonic Isolation Transformer is back in stock or available for preorder.
The Aquasonic Isolation Transformer is expertly designed for use when a no-conduction connection is required between an underwater speaker and the audio amplifier.
The Clark Synthesis Isolation Transformer is 96% efficient and is designed for use with our Aquasonic Diluvio Underwater Loudspeaker. It is acoustically transparent and housed in a moisture-resistant enclosure that has built-in mounting tabs attached.
The Clark Synthesis Isolation Transformer comes installed with two Neutrik Speakon receptacles and includes two cable mount Neutrik Speakon connectors for easy connection to amplifier and speaker wiring.
Note: Sales of this product are restricted to North America. Customers outside of North America that purchase this product receive no support or warranty from Clark Synthesis.
Dimensions: 6.25" H x 6.25" W x 4.375" D
BrandClark Synthesis
ModelAQP140
Part Number300-878
UPC645509100044
Weight6.5
