  • Ciare PW257 10" High Power Woofer
CLEARANCE Ciare PW257 10" High Power Woofer
CiarePart # 293-146
Model: PW257
With its low-frequency response and excellent sensitivity, the Ciare PW257 produces deep, rich bass and clear, detailed mid-range frequencies. The cone is made from a lightweight yet rigid material that allows for precise, accurate sound reproduction.
We'll send you an email when Ciare PW257 10" High Power Woofer is back in stock or available for preorder.
Introducing the Ciare PW257, the 10-inch high power woofer that's designed to deliver an unmatched audio experience. With a rugged build and high-quality materials, this speaker is engineered to withstand even the most demanding conditions.
The PW257 features a powerful ferrite magnet and a high-temperature voice coil that delivers exceptional performance, making it perfect for high-power applications. Whether you're building a custom home theater system, a professional sound system, or upgrading your car audio, the PW257 is the ideal choice.
Installation is a breeze thanks to the PW257's standard mounting options, and the speaker is compatible with a wide range of enclosures. Plus, its sleek and stylish design ensures it looks great no matter where you install it.
Overall, the Ciare PW257 is a top-of-the-line woofer that offers exceptional performance, durability, and versatility. Upgrade your sound system today with the PW257 and experience audio like never before.
BrandCiare
ModelPW257
Part Number293-146
UPC848864073217
Weight12.3
Nominal Diameter10"
Bolt Circle Diameter9.96
Power Handling (RMS)400 Watts
Power Handling (MAX)800 Watts
Frequency Response50 to 3,000Hz
Sensitivity96dB 2.83V/1m
Voice Coil Diameter3"
Resonant Frequency (Fs)57Hz
DC Resistance (Re)5.21Ω
Voice Coil Inductance (Le)0.94mH
Mechanical Q (Qms)3.2
Electromagnetic Q (Qes)0.33
Total Q (Qts)0.3
Compliance Equivalent Volume (Vas)1.09ft³
BL Product (BL)15.86T·m
Diaphragm Mass Inc. Airload (Mms)44.9g
Maximum Linear Excursion (Xmax)5.5mm
Surface Area of Cone (Sd)353cm²
Cone MaterialPaper
Surround MaterialCloth
Voice Coil FormerAluminum
Overall Outside Diameter10.55"
Baffle Cutout Diameter9.25"
Depth4.72"
Sealed Volume0.3ft³
Sealed F3152Hz
Vented Volume0.75ft³
Vented F370.4Hz
