  • Ciare HSG200-4 8" Subwoofer 4 Ohm
CLEARANCE Ciare HSG200-4 8" Subwoofer 4 Ohm
CiarePart # 293-162
Model: HSG200-4
The Ciare HSG200-4's solid build quality and advanced construction ensure that this woofer can handle high volumes without distortion, making it perfect for use in a wide range of applications. Its compact and efficient design makes it suitable for use in small to medium-sized speakers, as well as in automotive and marine audio systems.
  • Features an 8" cone constructed from high-strength fiber material, ensuring a flat frequency response and excellent transient response for precise audio reproduction.
  • Equipped with a ferrite magnet, providing a robust magnetic field within a durable and rugged design, enhancing overall performance and reliability.
  • Boasts a sleek and modern design, perfectly complementing both home and professional sound systems.
  • Its lightweight and compact size make installation effortless, allowing for easy incorporation into any audio setup without compromising on performance.
We'll send you an email when Ciare HSG200-4 8" Subwoofer 4 Ohm is back in stock or available for preorder.
The Ciare HSG200-4 8" Woofer is a high-performance speaker driver that delivers exceptional sound quality and power handling capabilities. This woofer features a 8" cone made from a high-strength fiber material that provides a flat frequency response and excellent transient response. The driver also features a ferrite magnet, which provides a strong magnetic field in a durable and rugged design.
The HSG200-4's sleek and modern design makes it a perfect complement to any home or professional sound system. Its lightweight and compact size make it easy to install and incorporate into any audio setup.
BrandCiare
ModelHSG200-4
Part Number293-162
UPC848864075426
Weight12.25
Nominal Diameter8"
Bolt Circle Diameter8.27
Power Handling (RMS)350 Watts
Power Handling (MAX)800 Watts
Frequency Response35 to 2,500Hz
Sensitivity88dB 2.83V/1m
Voice Coil Diameter3"
Resonant Frequency (Fs)39Hz
DC Resistance (Re)
Voice Coil Inductance (Le)1.5mH
Mechanical Q (Qms)4.7
Electromagnetic Q (Qes)0.39
Total Q (Qts)0.36
Compliance Equivalent Volume (Vas)0.67ft³
BL Product (BL)14.9T·m
Diaphragm Mass Inc. Airload (Mms)59.5g
Maximum Linear Excursion (Xmax)7.5mm
Surface Area of Cone (Sd)219cm²
Voice Coil FormerFiberglass
Overall Outside Diameter8.82"
Baffle Cutout Diameter7.24"
Depth4"
Sealed Volume0.134ft³
Sealed F392.14Hz
Vented Volume0.36ft³
Vented F351.6Hz
