  • Ciare CT441 1.75" Neodymium Horn Tweeter
CiarePart # 293-105
Model: CT441
The Ciare CT441 1.75" Neodymium Horn Tweeter combines high-efficiency performance with superior clarity, making it ideal for high-power audio applications. Its compact neodymium design delivers excellent power handling, while the horn structure enhances directional sound dispersion for focused high-frequency output.
  • 1.75" neodymium driver delivers high-frequency clarity and precision
  • Compact horn design provides enhanced directional sound dispersion
  • Efficient power handling up to 500 watts ensures optimal performance at higher volumes
  • Lightweight neodymium magnet offers excellent sensitivity for quick response
  • Durable materials support prolonged use in demanding environments
  • Optimized for integration into a variety of speaker systems and enclosures
Your Price: $164.25
Save $54.75 (25%)
We'll send you an email when Ciare CT441 1.75" Neodymium Horn Tweeter is back in stock or available for preorder.
The Ciare CT441 1.75" Neodymium Horn Tweeter is engineered to provide powerful high-frequency reproduction, delivering a sharp, detailed sound that stands out in professional audio setups. With its 1.75" neodymium driver, the CT441 ensures excellent clarity, making it the perfect tweeter for setups that demand precision in the higher frequency ranges. Whether you're working on a stage or enhancing a personal audio system, this tweeter offers the performance needed to deliver a rich, detailed sound experience.
One of the key advantages of the CT441 is its efficient horn design, which provides focused and directional sound dispersion. This helps to maximize the reach of high-frequency sound in larger environments, delivering clear, direct audio even at a distance. Its 250-watt power handling capability allows it to maintain exceptional performance even at high volumes, making it ideal for both professional live sound and high-output home speaker systems.
Built with long-lasting materials and a compact design, the CT441 is designed to withstand the demands of continuous use in various environments. Its neodymium magnet provides a lightweight structure without sacrificing power or sensitivity, ensuring quick and accurate sound response. Whether you’re integrating it into a new speaker design or upgrading an existing system, the CT441 offers flexibility, reliability, and high-performance sound.
  • Nominal Diameter: 44 mm (1.75 in)
  • Nominal Power: Handling 250 W
  • Sensitivity: 110 dB
  • Recommended Crossover: 2 kHz
  • Winding Material: Aluminum
  • Flux Density: 1.65 T
  • Nominal Impedance: 8 Ohms
  • Continuous Power Handling: 500 W
  • Frequency Range: 2,000 Hz - 20,000 Hz
  • Voice Coil Diameter: 44 mm (1.75 in)
  • Winding Depth: 2.7 mm (0.11 in)
Parameters
  • Fs: 1,400 Hz
  • Re: 4.5 Ω
Design:
  • Cone Shape: Planar
  • Con Material: Mylar
  • Connection Type: Faston
Mounting and Shipping Info
  • Overall Diameter: 112 mm
  • Baffle Cutout Diameter: 95 mm (3.75 in)
  • Flange and Gasket Thickness: 4 mm (0.16 in)
  • Bolt Quantity: 4 pcs
  • Bolt Circle Diameter: 116 mm (4.57 in)
  • Depth: 68 mm (2.68 in)
  • Net Weight: 0.8 kg (1.76 lb)
  • Basket Material: Aluminum
  • Bolt Diameter: 4.5 mm (0.18 in)
BrandCiare
ModelCT441
Part Number293-105
Weight1.65
Diaphragm MaterialPoly / Mylar
Exit Diameter1.75"
Mounting Type4-Bolt
Power Handling (RMS)250 Watts
Impedance8Ω
