  • Ciare CSD184-22 18" High Power Subwoofer Dual 2 Ohm
CLEARANCE Ciare CSD184-22 18" High Power Subwoofer Dual 2 Ohm
CiarePart # 293-174
Model: CSD184-22
Featuring a high-power 4 ohm voice coil, the Ciare CSD184-22 can handle up to 1000 watts of continuous power, making it ideal for use in high-output, professional-grade sound systems. The subwoofer also features a high-excursion design, allowing it to move large amounts of air and produce deep, impactful bass tones.
  • Designed for ultimate output and durability
  • Large 4" diameter voice coil for 1,000 watt power handling
  • High 13mm Xmax for added bass extension
  • Dual 2 ohm voice coils allow more wiring options
We'll send you an email when Ciare CSD184-22 18" High Power Subwoofer Dual 2 Ohm is back in stock or available for preorder.
Introducing the Ciare CSD184-22, a 12" high power subwoofer designed for the most demanding applications. With its robust construction and advanced features, this subwoofer delivers powerful, low-frequency output with exceptional clarity and accuracy.
To ensure long-lasting durability and reliability, the CSD184-22 is constructed using only the highest-quality materials, including a reinforced paper cone, large rubber surround, and heavy-duty steel frame. The subwoofer is also equipped with a vented pole piece and aluminum voice coil former, which help to dissipate heat and reduce power compression, ensuring maximum performance and efficiency. Dual 2 ohm voice coils allow more wiring options for a number of applications.
Whether you're a professional sound engineer or a serious audio enthusiast, the Ciare CSD184-22 is the perfect choice for achieving powerful, high-quality bass in any sound system.
BrandCiare
ModelCSD184-22
Part Number293-174
UPC848864075495
Weight36.55
Nominal Diameter18"
Bolt Circle Diameter17.32
Power Handling (RMS)500 Watts
Frequency Response20 to 200Hz
Sensitivity96dB 2.83V/1m
Voice Coil Diameter4"
Resonant Frequency (Fs)37Hz
DC Resistance (Re)3.5Ω
Voice Coil Inductance (Le)0.69mH
Mechanical Q (Qms)5.89
Electromagnetic Q (Qes)0.58
Total Q (Qts)0.53
Compliance Equivalent Volume (Vas)4.98ft³
BL Product (BL)18.52T·m
Diaphragm Mass Inc. Airload (Mms)246g
Maximum Linear Excursion (Xmax)13mm
Surface Area of Cone (Sd)1104cm²
Voice Coil FormerFiberglass
Overall Outside Diameter18.11"
Baffle Cutout Diameter16.38"
Depth8.7"
# Mounting Holes6
Sealed Volume2.789ft³
Sealed F360.13Hz
Vented Volume8.568ft³
Vented F328.99Hz
