  • Celestion TF0615MR 6" Professional Midrange Speaker 50W
CelestionPart # 294-2054
Model: TF0615MR
Devised specifically for midrange applications in professional PA speaker enclosures, the Celestion TF0615MR 6" mid driver offers high output, smooth response, and low distortion. Its closed-back steel chassis makes building a separate sub-enclosure unnecessary.
  • 97 dB sensitivity and 50 watts RMS power handling
  • 1.5" high temperature copper voice coil wound on polyimide former for increased reliability
  • Very compact model suitable for use in 3-way systems
  • Optimized to deliver detailed reproduction of mid-range frequencies
  • Closed back chassis simplifies cabinet manufacture, eliminating need for separate midrange enclosure
Your Price: $65.00
Save $23.50 (27%)
Only 2 In Stock
We'll send you an email when Celestion TF0615MR 6" Professional Midrange Speaker 50W is back in stock or available for preorder.
The Celestion TF0615MR 6" professional midrange speaker is a purpose-built device dedicated to high-SPL, low distortion reproduction of the critical midband frequencies. Its integrated sealed chassis isolates the driver's soft parts from the loudspeaker system woofer's "back pressure", while at the same time eliminating the need to construct a separate sub-enclosure. The TF0615MR features a 1.5" high-temp voice coil  and 17 oz. ceramic ferrite magnet, guaranteeing high efficiency and excellent power handling.
BrandCelestion
ModelTF0615MR
Part Number294-2054
UPC739894530842
Weight3.5
Nominal Diameter6"
Power Handling (RMS)50 Watts
Power Handling (MAX)100 Watts
Impedance8Ω
Frequency Response500 to 5,000Hz
Sensitivity97dB 2.83V/1m
Voice Coil Diameter1.5"
Resonant Frequency (Fs)553Hz
DC Resistance (Re)5.53Ω
Voice Coil Inductance (Le)0.29mH
Cone MaterialPaper / Kevlar
Surround MaterialTreated Paper
Overall Outside Diameter7.01"
Baffle Cutout Diameter5.79"
Depth2.91"
