  • Celestion Seventy 80 12" 8 Ohm Guitar Speaker 80W
CelestionPart # 294-2304
Model: Seventy 80
The Celestion Seventy 80 is a 12" guitar speaker with expanded frequency range, built to meet the needs often requested by a new generation of amp manufacturers. It is detailed and crisply defined, with a tightly controlled low-end, punchy aggressive upper mid-range, and a subtly increased top-end response.
  • Expanded frequency range for compatibility with modern amp voicings
  • Detailed and crisply defined response for clearer guitar articulation
  • Tightly controlled low-end for a firmer and more focused foundation
  • Punchy aggressive upper mid-range for stronger cut and presence
  • Subtly increased top-end response for added brightness and definition
  • Works singly in pairs or quartets for flexibility across different cabinet formats
  • Wide range of sounds and styles with unmistakable Celestion character
Your Price: $89.00
Save $38.50 (30%)
Only 1 In Stock More due on 11/13/2026
We'll send you an email when Celestion Seventy 80 12" 8 Ohm Guitar Speaker 80W is back in stock or available for preorder.
Order in the next 8 hr 49 min to ship today. Details
One of our most popular models, this 12" guitar speaker is designed to cover the broader frequency range often sought by today’s amp manufacturers. The Seventy 80 delivers detailed, clearly defined sound with a tight low end, a punchy aggressive upper midrange, and a slightly more pronounced top end. Whether used alone, in pairs, or in quartets, it can handle a wide variety of tones and playing styles while bringing unmistakable Celestion character to any amp.
  • Nominal diameter: 305mm / 12in
  • Power rating: 80W
  • Rated impedance: 8Ω
  • Sensitivity: 98dB
  • Chassis type: Pressed steel
  • Magnet type: Ceramic
  • Magnet weight: 0.88kg / 31oz
  • Voice coil diameter: 1.75in / 44.5mm
  • Voice coil material: Round copper
  • Frequency range: 80-5000Hz
  • Resonance frequency, Fs: 85Hz
  • DC resistance, Re: 6.1Ω
  • Diameter: 309mm / 12.2in
  • Magnet structure diameter: 134mm / 5.3in
  • Mounting hole dimensions: 7.9mm / 0.31in Ø
  • Mounting hole PCD: 297mm / 11.7in
  • Number of mounting holes: 4
  • Overall depth: 119mm / 4.7in
  • Unit weight: 3.1kg / 6.8lb
Frequency Response
BrandCelestion
ModelSeventy 80
Part Number294-2304
UPC739894560559
Weight7.15
Nominal Diameter12"
Power Handling (RMS)80 Watts
Impedance8Ω
