Celestion Peacekeeper 12" Attenuating Guitar Speaker 8 Ohm
The Celestion Peacekeeper is a 12″ attenuating guitar speaker designed to let you push tube amps into their sweet spot at much lower volume. By significantly reducing output sensitivity without altering tone, it delivers cranked-amp sound while keeping levels manageable. Its drop‑in design works with standard cabs and amps, ideal for recording, small venues, and bedroom guitarists.
- Attenuating dual‑voice‑coil design lowers output sensitivity
- Preserves amp tone organically with no added coloration
- Standard 12″ size and 8 Ω impedance for wide compatibility
- Dual voice coil design enables cranked amp tone without excessive volume
- Power‑handling rated 50 W to match common tube amps
- Low 86 dB sensitivity equates to quieter playback
- Precision Built in the UK
We'll send you an email when Celestion Peacekeeper 12" Attenuating Guitar Speaker 8 Ohm is back in stock or available for preorder.
