  • Celestion G12T-75 12" 16 Ohm Guitar Speaker 75W
CLEARANCE Celestion G12T-75 12" 16 Ohm Guitar Speaker 75W
CelestionPart # 294-2272
Model: G12T-75
Celestion's G12T-75 16 ohm speaker is seen by many as the ultimate incarnation of the original Celestion G12M model – a Greenback on steroids! With its aggressive and spiky tonal qualities, the G12T-75 has featured extensively in cabinets like the legendary Marshall 1960.
Celestion Neo V-Type 12" Guitar Speaker 70W 16 Ohm
Price: $159.00Part # 294-1982
See all items in Guitar Speakers & Bass Guitar Speakers
We'll send you an email when Celestion G12T-75 12" 16 Ohm Guitar Speaker 75W is back in stock or available for preorder.
Featured in the world's top selling 4x12 cabinet, the G12T-75 is a high powered rock player's dream. The best selling guitar speaker of all time, the G12T-75 is in fact remarkably versatile, staying clean at thunderously high volume levels. Built to meet the demands of high gain amplifiers, the G12T-75 combines a huge, tightly controlled low-end and aggressive mid-range with a softened top-end that adds a welcome sweetness to overdrive, distortion and aggressive upper harmonics. These are the characteristics that make the G12T-75 the weapon of choice for Yngwie Malmsteen.
Overall Specifications: • Nominal diameter: 12" (305 mm) • Power rating: 75 watts • Nominal impedance: 16 ohm • Sensitivity: 97 dB • Chassis type: Pressed steel • VCdia: 1.75" (44.5 mm) • Voice coil material: Round copper • Magnet type: Ceramic • Frequency range: 80-5,000 Hz • Fs: 85 Hz • DC resistance, Re: 12.9 ohm.
Mounting Information: • Diameter: 12.2" (309 mm) • Overall depth: 5" (127 mm) • Magnet structure diameter: 5.7" (145 mm) • Cut-out diameter: 11.1" (283 mm) • Mounting slot dimensions: 0.31" (7.9 mm Ø) • Number of mounting slots: 4 • Mounting slot PCD: 11.7" (297 mm) • Weight: 7.7 lbs. (3.5 kg).
BrandCelestion
ModelG12T-75
Part Number294-2272
UPC739894376051
Weight9.55
Nominal Diameter12"
Power Handling (RMS)75 Watts
Impedance16Ω
