  • Celestion G12M50 Hempback 12" Guitar Speaker 50W 8 Ohm
CelestionPart # 294-1978
Model: G12M50
Read 1 Review or
Announcing the introduction of the Celesion G12M-50 Hempback, a new guitar speaker which takes Celestion tone in an exciting new direction.
Your Price: $139.00
MSRP: $208.50
Save $69.50 (33%)
We'll send you an email when Celestion G12M50 Hempback 12" Guitar Speaker 50W 8 Ohm is back in stock or available for preorder.
The G12M-50 Hempback is the first ever hemp cone guitar speaker built by Celestion. It features a cone specifically chosen for its tonal character combined with a medium-weight (35oz) ceramic magnet, well defined and powerful the speaker delivers a thump in the low end, a finely balanced midrange (with just a little Celestion crunch thrown in) and smooth, singing highs. It all adds up to a speaker that’s perfect for deploying with brighter sounding amps, where a more laid- back feel is required. Load up a Hempback for a smooth and “smoky” sound that’s musical and responsive, and let the hemp tone shine through.
Overall Specifications: • Nominal diameter: 12" (305 mm) • Power rating: 50 watts • Nominal impedance: 8 ohm • Sensitivity: 99 dB • Chassis type: Pressed steel • VCdia: 1.75" (44.5 mm) • Voice coil material: Round copper • Magnet type: Ceramic • Frequency range: 75-5,000 Hz • Fs: 75 Hz
Mounting Information: • Diameter: 12.2" (309 mm) • Overall depth: 5.1" (130 mm) • Magnet structure diameter: 5.9" (150 mm) • Cut-out diameter: 11.1" (283 mm) • Mounting slot dimensions: 0.31" (7.9 mm Ø) • Number of mounting slots: 8 • Mounting slot PCD: 11.7" (297 mm) • Weight: 7.9 lbs. (3.6 kg).
BrandCelestion
ModelG12M50
Part Number294-1978
UPC739894647205
Weight9.4
