  • Celestion G12K-100 12" 8 Ohm Guitar Speaker 100W
CelestionPart # 294-2286
Model: G12K-100
2 Questions, 1 Answer or
The G12K-100 is Celestion's premium 100 watt driver and it's a beast! Featuring the heaviest G12 magnet currently in use, it combines substantial power handling with exceptional sensitivity, detail and clarity
Your Price: $159.00
MSRP: $238.50
Save $79.50 (33%)
We'll send you an email when Celestion G12K-100 12" 8 Ohm Guitar Speaker 100W is back in stock or available for preorder.
Estimated back in stock 9/5/2025
Celestion's very own monster of rock, the G12K-100, makes full use of the heaviest G12 magnet to combine huge power handling with superb clarity across a wide frequency response. A massive bottom-end, rock-hard midrange and restrained top-end make this the perfect speaker to add thump and grind to modern high-gain tones.
Loaded in 4x12s it delivers its famous sledgehammer lows, as favoured by Slayer’s Kerry King, but it also often finds use in small boutique combos, bringing a powerful mix of low-end warmth and mid-range attack.
Overall Specifications: • Nominal diameter: 12" (305 mm) • Power rating: 100 watts • Nominal impedance: 8 ohm • Sensitivity: 99 dB • Chassis type: Pressed steel • VCdia: 1.75" (44.5 mm) • Voice coil material: Round copper • Magnet type: Ceramic • Frequency range: 80-5,500 Hz • Fs: 85 Hz • DC resistance, Re: 7 ohm.
Mounting Information: • Diameter: 12.2" (309 mm) • Overall depth: 5.3" (135 mm) • Magnet structure diameter: 6.1" (156 mm) • Cut-out diameter: 11.1" (283 mm) • Mounting slot dimensions: 0.31" (7.9 mm Ø) • Number of mounting slots: 4 • Mounting slot PCD: 11.7" (297 mm) • Weight: 10.4 lbs. (4.7 kg).
BrandCelestion
ModelG12K-100
Part Number294-2286
UPC739894358545
Weight10.6
Nominal Diameter12"
Power Handling (RMS)100 Watts
