  • Celestion CDX1-1745 Ferrite 1" Compression Driver 75W
CelestionPart # 294-2124
Model: CDX1-1745
For an unbeatable combination of durability, listenability, and sustainable high output, choose the Celestion CDX1-1745 1" bolt-on HF driver.
  • 1" exit, ferrite magnet compression driver with 1.75" edgewound copper-clad aluminum voice coil
  • 75 watts RMS power handling and 110 dB sensitivity
  • Sound Castle™ clamping ensures even pressure on diaphragm assembly for reduced distortion
  • One-piece PETP diaphragm and surround for clean, extended response
  • Finite Element Analysis (FEA) used to optimize both magnet assembly and acoustic design
Your Price: $109.00
Save $39.50 (27%)
We'll send you an email when Celestion CDX1-1745 Ferrite 1" Compression Driver 75W is back in stock or available for preorder.
The Celestion CDX1-1745 1" HF driver uses FEA optimization on its moving parts as well as its magnetic circuit. The result is extreme efficiency, high power handling, and very low distortion. The CDX1-1745 is capable of delivering stunningly clear, hi-fi quality output, but at the explosive sound reinforcement levels demanded of pro loudspeaker systems. Also available in a 1-3/8"-18 TPI screw-on version, the CDX1-1746.
Specifications: • Power handling: 75 watts RMS (AES standard) • Recommended min. crossover: 2,200 kHz, 12 dB/octave • VCdia: 1.75" • Impedance: 8 ohms • Frequency range: 1,200-20,000 Hz • Sensitivity: 110 dB 1W/1m • Mounting (flange): 2/3 x M6 holes on 3/2.24" PCD • Dimensions: 4.7" dia. x 2.2" depth • Net weight: 5.1 lbs.
BrandCelestion
ModelCDX1-1745
Part Number294-2124
UPC739894536349
Weight4.55
Diaphragm MaterialPoly / Mylar
Exit Diameter1"
Mounting Type2-Bolt/3-Bolt
Power Handling (RMS)75 Watts
Impedance8Ω
