  • Celestion BL15-300X 15" 300W Bass Guitar Speaker 4 Ohm
CelestionPart # 294-2459
Model: BL15-300X
From Celestion's the Green Label Series, the BL15-300X 4 ohm 15" bass driver, is built for high-power rock performances, where a full-bodied, warm, and defined tone is essential.
  • Extended low frequency response for improved bottom end thump
  • Bumped back plate prevents voice coil from bottoming out
  • 300 Watts RMS and 96dB efficiency for high output with little effort
Your Price: $135.00
MSRP: $202.50
Save $67.50 (33%)
We'll send you an email when Celestion BL15-300X 15" 300W Bass Guitar Speaker 4 Ohm is back in stock or available for preorder.
Not every player wants a super-clean, high-fidelity bass sound. Characterized by an extended low end and greater linear excursion, Green Label speakers push out every note with a rich, warm tone and a powerful low-end thump. Green Label speakers are primed for high-powered rock performances, where a full-bodied, warm, defined tone is essential.
Overall Specifications: • Nominal diameter: 15" • Power rating: 300 watts • Nominal impedance: 4 ohm • Sensitivity: 96 dB • VCdia: 2.5" • Voice coil material: Copper • Magnet type: Ferrite • Frequency range: 42-3,500 Hz • Fs: 48.1 Hz • Re: 3.15 ohm.
Mounting Information: • Diameter: 15.2" (385 mm) • Overall depth: 6.4" • Cut-out diameter: 13.8" • Weight: 10.6 lbs.
BrandCelestion
ModelBL15-300X
Part Number294-2459
UPC739894563550
Weight12.85
Nominal Diameter15"
Power Handling (RMS)300 Watts
