  • Celestion BL10-100X 10" 100W Bass Guitar Speaker 8 Ohm
CelestionPart # 294-2454
Model: BL10-100X
Celestion's BN10-100X 10" bass guitar speaker is perfect for high-powered rock performances by producing a warm, defined tone.
  • Ceramic ferrite motor structure that delivers full body tones
  • Extended low end and greater linear excursion
  • Perfect for the high-powered rock performance
Your Price: $85.00
MSRP: $127.50
Save $42.50 (33%)
We'll send you an email when Celestion BL10-100X 10" 100W Bass Guitar Speaker 8 Ohm is back in stock or available for preorder.
Estimated back in stock 1/9/2026
The Celestion BN10-100X is characterized by extended low end sounds, and extreme amounts of linear excursion. The Green Label speakers push out rich, warm tones and powerful low end thumps with every note! These professional drivers deliver a three-dimensional musical quality that is the heart and soul of Celestion's bass guitar speakers.
Overall Specifications: • Nominal diameter: 10" • Power rating: 100 watts • Nominal impedance: 8 ohms • Sensitivity: 94 dB • Chassis type: Pressed steel • VCdia: 1.5" • Voice coil material: Copper • Magnet type: ferrite • Frequency range: 45-3,500 Hz • Fs: 76 Hz • DC resistance, Re: 6.67 ohms.
Mounting Information: • Diameter: 10.1" • Overall depth: 4.4" • Cut-out diameter: 9" • Number of mounting holes: 4 • Weight: 5.3 lbs.
BrandCelestion
ModelBL10-100X
Part Number294-2454
UPC739894562959
Weight6.5
Nominal Diameter10"
Power Handling (RMS)100 Watts
