  • Cat 6 UTP Ethernet Network Patch Cable 550 MHz 50 ft. Green
CLEARANCE Cat 6 UTP Ethernet Network Patch Cable 550 MHz 50 ft. Green
Parts ExpressPart # 150-437
Improve your home or office network connection speeds using Category 6 Ethernet patch cables. Useful for connecting local area network (LAN) / wide area network (WAN) segments, hubs, switchers, routers, patch panels, and other unshielded twisted-pair (UTP) applications.
  • 4-pair 24 AWG stranded copper conductors with a PVC jacket for great performance in home and office networking applications
  • Supports a bandwidth up to 550 MHz for improved transfer speeds
  • Outperform Category 5e (Cat5e) cables
  • For use with LAN/WAN segments and other UTP applications
  • Molded strain relief with snagless design protects RJ45 connectors
CLEARANCE $8.86
MSRP: $15.99
Save $7.13 (45%)
3 In Stock
We'll send you an email when Cat 6 UTP Ethernet Network Patch Cable 550 MHz 50 ft. Green is back in stock or available for preorder.
Given the ability to be used with LAN/WAN segments, hubs, switches, routers, patch panels, and other UTP applications, Category 6 Ethernet patch cables provide a high transfer speed solution for your home or office network patching needs. The cable has a RJ45 connector on each end with molded strain relief for durability, and gold plated pins for improved connectivity. RoHS compliant.
Specifications: • Conductor: 4-pair 24 AWG stranded copper • Bandwidth: 550 MHz • Jacket: PVC • Exceeds Category 5e specifications.
Part Number150-437
UPC848864033600
Weight1.4
Cable Length50feet
Cable TypeCategory 6
Jacket ColorGreen
Special FeaturesMolded Strain Relief-Snagless
