  • Cat 6 550 MHz Direct Bury Gel 1000 Ft.
CLEARANCE Cat 6 550 MHz Direct Bury Gel 1000 Ft.
Parts ExpressPart # 101-440
The 1,000 ft. Cat 6 cable's design is perfect for outdoor or direct burial use. The polyethylene jacket can withstand extreme temperatures and moisture.
  • 23 gauge solid bare copper insulated conductors twisted into pairs
  • Core filled with water blocking gel
  • RoHS approved
  • Meets ISO/IEC 11801 and ANSI/EIA/TIA 568-C.2-1 Specs
We'll send you an email when Cat 6 550 MHz Direct Bury Gel 1000 Ft. is back in stock or available for preorder.
Install this outdoor Cat 6 cable above ground or underground with confidence. The cables polyethylene insulation and outer jacket will not dry out and crack, do to UV rays or extreme temperatures. Inside the jacket is a gel flooding compound to prevent water ingress. The 23 gauge solid bare copper insulated conductors twisted into pairs are ready for long runs.
Specifications: • Overall diameter: 0.28" • Jacket thickness: 0.0205".
Part Number101-440
UPC848864040004
Weight37.95
Cable TypeCategory 6
Jacket ColorBlack
Wire Gauge23
Special FeaturesDirect Burial-UV Resistant
