  • AM FM Hidden Antenna for Vehicle Car Radio Truck Behind Windshield with 16ft extension wire and radio plug
CLEARANCE AM FM Hidden Antenna for Vehicle Car Radio Truck Behind Windshield with 16ft extension wire and radio plug
Parts ExpressPart # 265-011
Pick up AM/FM reception the easy way by sticking this hide-away antenna out-of-sight. The 3M peel-n-stick adhesive holds tight wherever you put it.
  • Quick peel-n-stick installation
  • Perfect boats, ATVs, and golf carts that don't have stock AM/FM antennas
  • Standard Motorola antenna plug fits most aftermarket car stereos
  • 4-1/2" x 7/8" x 1/4" size fits almost anywhere
  • 16 ft. cord for multiple applications
We'll send you an email when AM FM Hidden Antenna for Vehicle Car Radio Truck Behind Windshield with 16ft extension wire and radio plug is back in stock or available for preorder.
All car radios need some kind of antenna to receive any AM/FM radio stations. Now you never have to worry about how to mount the antenna. This hide-away antenna mounts almost anywhere. It's small size and 3M peel-n-stick tape mounts under the dash of most on and off-road vehicles. No hole mounting makes it perfect for boats, ATVs, and golf carts which usually don't have stock AM/FM radio antennas. The 16ft. cord enables you to stick it far away from the radio if needed. Always mount the antenna with painter's tape first, to test your reception before mounting it permanently with the 3M peel-n-stick adhesive. Try not to mount it under metal for best reception.
Part Number265-011
UPC848864071244
Weight0.15
