  • CES SP-0039 4" Replacement Speaker 4 Ohm
BUYOUT CES SP-0039 4" Replacement Speaker 4 Ohm
Factory BuyoutsPart # 299-218
Model: SP-0039
The CES SP-0039 4" Replacement Speaker uses a paper cone and inverted cloth surround for natural audio reproduction. The unique square frame makes this a good choice for close center-to-center mounting, perfect for full-range speaker arrays.
  • Paper cone and inverted cloth surround for natural audio reproduction
  • 4 ohm impedance
  • 5/8” copper voice coil
BUYOUT $0.94
MSRP: $1.88
Save $0.94 (50%)
9336 In Stock
We'll send you an email when CES SP-0039 4" Replacement Speaker 4 Ohm is back in stock or available for preorder.
Order in the next 15 hr 54 min to ship today. Details
The CES SP-0039 4" Replacement Speaker utilizes a unique square frame to allow for closer center-to-center mounting. With a wide 3-1/8" diameter spider for clean excursion ability and treated cloth surround, this is designed to last for years. It’s small size and full range ability also make it a good choice for a cost effective speaker in a custom array system.
BrandCoast Buyouts
ModelSP-0039
Part Number299-218
UPC848864072050
Weight0.66
Nominal Diameter4"
Bolt Circle Diameter4.5
Power Handling (RMS)4 Watts
Power Handling (MAX)8 Watts
Frequency Response150-8,000Hz
Sensitivity88.7dB 2.83V/1m
Voice Coil Diameter0.625"
Resonant Frequency (Fs)156.5Hz
DC Resistance (Re)3.691Ω
Voice Coil Inductance (Le)0.098mH
Mechanical Q (Qms)3.534
Electromagnetic Q (Qes)1.612
Total Q (Qts)1.107
Compliance Equivalent Volume (Vas)0.07121ft³
Diaphragm Mass Inc. Airload (Mms)2.01g
Maximum Linear Excursion (Xmax)0.5mm
Surface Area of Cone (Sd)52.81cm²
Cone MaterialPaper
Surround MaterialCloth
Voice Coil FormerPaper
Overall Outside Diameter4"
Baffle Cutout Diameter4"
Depth1.875"
