  • Dalco Cat6 Patch Cable - 7 ft. Gray
CLEARANCE Dalco Cat6 Patch Cable - 7 ft. Gray
Dalco ElectronicsPart # 69600
Model: UPT-4P6-7S-GRAY
1 Question, 1 Answer or
Improve your home or office network connection speeds using Category 6 Ethernet patch cables. Useful for connecting local area network (LAN) / wide area network (WAN) segments, hubs, switchers, routers, patch panels, and other unshielded twisted-pair (UTP) applications.
  • 4-pair 24 AWG stranded copper conductors with a PVC jacket for great performance in home and office networking applications
  • Supports a bandwidth up to 550 MHz for improved transfer speeds
  • 50µ gold plated RJ45 connectors
  • For use with LAN/WAN segments and other UTP applications
  • Molded strain relief with snagless design protects RJ45 connectors
  • Outperform Category 5e (Cat5e) cables
  • UL listed and RoHS compliant
CLEARANCE $2.22
MSRP: $2.99
Save $0.77 (26%)
7 In Stock
We'll send you an email when Dalco Cat6 Patch Cable - 7 ft. Gray is back in stock or available for preorder.
Order in the next 2 hr 49 min to ship today. Details
Given the ability to be used with LAN/WAN segments, hubs, switches, routers, patch panels, and other UTP applications, Category 6 Ethernet patch cables provide a high transfer speed solution for your home or office network patching needs. The cable has a RJ45 connector on each end with molded strain relief for durability, and gold plated pins for improved connectivity. RoHS compliant.
Specifications: • Conductor: 4-pair 24 AWG stranded copper • Bandwidth: 550 MHz • Jacket: PVC • Exceeds Category 5e specifications.
BrandDalco Electronics
ModelUPT-4P6-7S-GRAY
Part Number69600
UPC848864040615
Weight0.18
Cable Length7feet
Cable TypeCategory 6
Jacket ColorGray
