  • CAIG RSF-R80-8 DeoxIT Rosin Soldering Flux Jar 226g
CAIG LaboratoriesPart # 341-222
Model: RSF-R80-8
Soldering is made easier with CAIG's DeoxIT rosin soldering flux. Soldering flux from CAIG permits soldering of difficult metals, such as brass or nickel, and can be easily removed with a cloth or solvent, and features a non-spill consistency with a nonflammable formulation. 226 gram jar.
  • Helps solder flow more smoothly for better solder joints
  • Non-spill consistency and nonflammable formulation
  • Permits soldering of difficult metals such as brass or nickel
Your Price: $34.34
MSRP: $38.95
Save $4.61 (12%)
We'll send you an email when CAIG RSF-R80-8 DeoxIT Rosin Soldering Flux Jar 226g is back in stock or available for preorder.
Rosin soldering flux helps solder flow more smoothly, creating a better contact and making a better solder joint. The DeoxIT brand soldering flux from CAIG permits soldering of difficult metals, such as brass or nickel, and can be easily removed with a cloth or solvent.
A non-spill consistency and nonflammable formulation makes DeoxIT rosin perfect for both mass production use and at home for hobbyists. CAIG's DeoxIT brand rosin soldering flux meets DOD-STD-2000 and the IPC-J-004 standard for type ROL0, the lowest residue corrosivity category. 226 gram jar.
BrandCAIG Laboratories
ModelRSF-R80-8
Part Number341-222
UPC697429014079
Weight0.6
