This feature rich Bluetooth receiver packs an impressive amount of technology in a small package. Great for adding Bluetooth to home audio amplifiers, car stereos, or even headphones. Intuitive design allows you to play, pause, and answer calls with a simple press of a button.
Dual link feature allows you to pair to two different devices at once.
Specifications: • Bluetooth version: 4.1 + EDR • Frequency Range: .4 GHz - 2.4 GHz • Bluetooth mode: A2DP/AVRCP/HFP/HSP • Output power category: Class 2 • Input: Bluetooth • Output: 3.5 mm • Power supply: Li-Po 60 mAh • Charge Voltage: 5.0 VDC • Bluetooth range: 30 feet max • Dimensions: 1/2" H x 1/2" W x 2-3/4" D
