  • Beyma CP-21/F Compression Tweeter 8 Ohm
NEW Beyma CP-21/F Compression Tweeter 8 Ohm
BeymaPart # 253-155
Model: CP-21/F
The Beyma CP21/F is a high-output 1.5" aluminum compression tweeter designed for smooth high-frequency performance with ultra-wide dispersion. With its flat front and rugged build, it’s well suited for professional sound systems demanding a focused, articulate top-end response.
  • 1.5" edgewound aluminum voice coil offers low moving mass and fast response
  • Aluminum diaphragm delivers sharp transients and reduced distortion
  • Ultra-wide 140° horizontal dispersion for broad sound coverage
  • Designed for applications with need of wide horizontal dispersion and precise high frequency coverage
  • Recommended crossover at 5 kHz with 12 dB/oct slope or higher
NEW $114.00
MSRP: $152.00
Save $38.00 (25%)
We'll send you an email when Beyma CP-21/F Compression Tweeter 8 Ohm is back in stock or available for preorder.
Order in the next 5 hr 3 min to ship today. Details
The CP21/F is engineered to deliver crisp, intelligible highs across a wide listening area, making it a standout component in multi-angle PA systems and stage monitors. Its 1.5" aluminum diaphragm and edgewound voice coil allow for quick transient response and excellent definition, while maintaining high efficiency even under sustained use. The 140° horizontal coverage ensures consistent projection across a broad field, ideal for venues where wide dispersion is critical. A recommended high-pass filter at 5 kHz with a minimum 12 dB/octave slope will ensure a clean integration with midrange drivers, protecting the tweeter from overload. The CP21/F’s compact flat-front design allows for flush mounting, making it a versatile option for tight enclosures or custom builds that demand reliable high-frequency performance.
BrandBeyma
ModelCP-21/F
Part Number253-155
UPC8435469044845
Weight3.85
Diaphragm MaterialAluminum
Power Handling (RMS)25 Watts
