  • Beyma CD-1114Fe 1.4" Compression Driver 8 Ohm 4-Bolt
NEW Beyma CD-1114Fe 1.4" Compression Driver 8 Ohm 4-Bolt
BeymaPart # 253-136
Model: CD-1114Fe
The Beyma CD-1114Fe is a 1.4" high-frequency compression driver designed for professional audio systems requiring high sensitivity and natural sound reproduction. Its robust construction and advanced materials make it suitable for various demanding audio applications.
  • 1.75" DUO double-layer aluminum voice coil enhances durability​
  • PM4 polymer diaphragm offers natural sound reproduction​
  • FEA-optimized ferrite motor structure improves performance​
  • Aluminum cover provides structural integrity​
NEW $105.00
MSRP: $140.00
Save $35.00 (25%)
We'll send you an email when Beyma CD-1114Fe 1.4" Compression Driver 8 Ohm 4-Bolt is back in stock or available for preorder.
The CD-1114Fe's combination of high power handling and sensitivity enables it to deliver clear and dynamic high-frequency output. The DUO double-layer aluminum voice coil enhances thermal stability, contributing to consistent performance. The PM4 polymer diaphragm ensures natural sound reproduction, while the FEA-optimized ferrite motor structure enhances overall efficiency. The aluminum cover adds durability, making this compression driver a reliable choice for professional audio systems.
Beyma's Research and Development department collaborates closely with the Technical Office to conduct practical experiments that demonstrate and share acquired knowledge. A notable outcome of this research is the development of the PM4 diaphragm, which incorporates a high-tech polymer previously unused in audio applications.
This innovation results in a stronger bond between the dome and the voice coil former, enhancing performance under high power and prolonged use. Subjectively, Beyma's evaluations suggest that the PM4 diaphragm offers a more natural sound compared to other polyester materials.
BrandBeyma
ModelCD-1114Fe
Part Number253-136
UPC8435469044562
Weight4.4
Exit Diameter1.4"
Mounting Type4-Bolt
Power Handling (RMS)70 Watts
