  • Beston RT003C Round Ribbon Tweeter 6 Ohm
BestonPart # 277-114
Model: RT003C
The Beston RT003C's low-mass aluminum diaphragm and high strength/low weight neodymium motor deliver incredible articulation and transient attack.
  • Patented ribbon design
  • 2,500 Hz – 40,000 Hz frequency response
  • Integral phase-correction plug
  • Linear impedance
  • Neodymium magnet structure for high flux and low weight
  • Ultra-thin laminated aluminum diaphragm
Your Price: $39.98
Save $12.01 (23%)
We'll send you an email when Beston RT003C Round Ribbon Tweeter 6 Ohm is back in stock or available for preorder.
The Beston RT003C's low-mass aluminum diaphragm and high strength/low weight neodymium motor deliver incredible articulation and transient attack. Frequency response actually extends to 40 kHz! The tweeter is ideal for applications demanding compact size, high efficiency, and maximum fidelity. A third order (18 dB/octave) or higher crossover is recommended to achieve maximum power handling. Minimum recommended crossover frequency: 4,000 Hz
BrandBeston
ModelRT003C
Part Number277-114
UPC844632069826
Weight0.4
Cutout Diameter2.00
Tweeter TypeRibbon
Power Handling (RMS)15 Watts
Frequency Response2,500 to 40,000Hz
Sensitivity93dB 2.83V/1m
DC Resistance (Re)5.8Ω
Overall Outside Diameter3.06"
Depth1.12"
