Behringer ULM202USB Ultralink USB Dual Wireless Microphone SystemOnce again, Behringer breaks the affordability barrier with the new Ultralink ULM Series USB wireless microphone system. Now you are free to work the room to your heart's content, without the worry and restriction of cables underfoot. High quality sound is provided by the dynamic handheld mic/transmitters, which operate in the license-free 2.4 GHz range. The USB receiver dongle plugs into a dedicated port on compatible Wireless Ready Behringer gear, and BOOM! You're done. Easy as that. And, the receiver can also be connected directly to your PC/Mac computer's USB port, so you can record directly into your favorite DAW application.
Interference-Free Performance
Behringer's state-of-the-art ULM transmitters and receivers operate in the 2.4 GHz frequency band, which is well out of the way of TV stations and cell phone towers, two of the main culprits that wreak havoc in the wireless zone. And because it is digitally encrypted, your signal gets through in all its pristine, high-definition quality, without the random artifacts that often plague other wireless systems.
Extended Battery Life
Replacing batteries in wireless mics can get really expensive, really fast, and having them die in the middle of your set can be a showstopper! That's why Behringer devoted extra time in developing the ULM Series, ensuring that battery life is extended as long as possible. You get an honest 8 hours performance time from a pair of AA alkaline batteries, which are available virtually anywhere on the planet.
Convenient Control
It can be a real hassle running back and forth to get your volume set just right, so Behringer put easy-to-operate Volume Up and Down buttons right on the microphone body. And should you accidentally wander into the "Feedback Zone," they've included a handy Panic/Mute function that engages when you press and hold the Volume Down button.
Behringer Value
The ULM Series wireless USB microphone system and Wireless Ready PA equipment are only available from Behringer, the premier audio manufacturer recognized worldwide for outstanding build quality and exceptional value. For superb sound, ease of use, and reliability, nobody beats Behringer.
Specifications: • Frequency response: 20 - 15,000 Hz • Operating range: up to 390 ft. (120 m), line-of-sight • Sampling rate: 48 kHz/24-bit • Encoding: 232 kbps SLAC • RF channel: 2.4 GHz ISM band (2406-2474 MHz); 18 channels • Batteries: AA x 2 • Battery life: 8 hours • Microphone dimensions: 1.8" x 9.6" (45 x 245 mm).
