Behringer NX4-6000 Ultra Lightweight 4 Channel Class D 6000W Power AmplifierProviding seemingly effortless power to your rig, the Behringer NX4-6000 Class D power amplifier has the ability to drive the most demanding systems. The NX4-6000 power amplifier runs much cooler than counterparts by employing an ultra-efficient power supply. In addition to a reliable, efficient amp, the NX4-6000's feather-light rack-mountable chassis provides the ultimate portability.
Featuring Class D amplifier technology, the NX4-6000 provides enormous power and excellent sonic performance while remaining lightweight, easy to use, and ultra-portable. High-density Class D amplification eliminates the need for power supplies and delivers highly efficient output. Not only are the NX4-6000s lighter in weight than counterparts, they also use less energy while retaining extremely powerful output.
Don't worry about overloading your system with the built-in "Zero-Attack" limiter which ensures maximum output without overloads. Behringer's SmartSense Technology provides a detailed full-range frequency response with powerful, dynamic bass and silky high-frequency response. The technology ensures the output is not dependent on the actual load of the speakers and produces a flat response via impedance compensation. Incorporating a higher damping factor, the NX4-6000 yields better amplifier control over the speakers for stronger audio reproduction.
With a glance monitor the vial signs of the NX4-6000. The front panel controls and indicators make monitoring signal extremely easy. Each channel features positive-detent gain controls with signal and limit LEDs to provide real time output feedback. The back panel features combo XLR and 1/4" TRS combo input jacks making the NX4-6000 compatible with both unbalanced and balanced sources. Professional twist lock speakon type connectors ensure a secure connection to loudspeakers.
The amp can be ran in dual mono, stereo, or mono bridge modes. The built-in crossover also provides you with the ability to set the amp as a full-range output or as a bi-amp output featuring high and low cut filters.
Supporting massive power in a lightweight chassis, the NX4-6000 carries an equally lightweight price tag. With all the power and amenities that the professional audio engineer needs, the Behringer NX4-6000 power amplifier performs exceptionally for the most demanding applications.
Specifications: • Power output: 4 x 1600W @ 2 ohms, 4 x 860W @ 4 ohms, 4 x 440W @ 8 ohms • Bridged power output: 2 x 3000W @ 4 ohms, 2 x 1600W @ 8 ohms • Inputs: 4 x combo jacks • Input impedance: 10K ohms (unbalanced), 20k ohms (balanced) • Outputs: 4 x speakon type connectors • Output circuit type: Class D • Frequency response: 20 - 20,000 Hz • Cooling: Continuously variable speed fan • Amplifier protection: Thermal and DC protection • Dimensions: 3.7" H x 19" W x 9.1" D.
