  • Behringer DEQ2496 Ultracurve Pro Digital EQ/RTA
CLEARANCE Behringer DEQ2496 Ultracurve Pro Digital EQ/RTA
BehringerPart # 248-661
Model: DEQ2496
The Ultracurve PRO DEQ2496 is an ultra high-precision digital 24-bit/96 kHz EQ/RTA mastering processor. Its extremely high audio performance makes it ideal for audiophile mastering and PA purposes.
  • Ultra high-resolution processor for all EQ, RTA and dynamic applications
  • Outstanding tool for PA applications and audiophile mastering
  • 4 concurrently selectable EQ modules
  • Flexible compressor/expander function with peak limiter per stereo channel
  • Stereo delay for delay line applications
  • Unique VPQ (Virtual Paragraphic EQ) option allows parametric control of graphic EQs
  • 61-band real-time FFT analyzer with auto EQ function for system equalization
We'll send you an email when Behringer DEQ2496 Ultracurve Pro Digital EQ/RTA is back in stock or available for preorder.
The Ultracurve PRO DEQ2496 is an ultra high-precision digital 24-bit/96 kHz EQ/RTA mastering processor. Its extremely high audio performance makes it ideal for audiophile mastering and PA purposes. There are 4 concurrently selectable EQ modules (31-band graphic EQ, 10-band parametric EQ, Feedback Destroyer and three dynamic EQs per channel). Another highlight is the additional 61-band RTA that can run simultaneously with the EQ section.
The DEQ2496 features high-quality AKM® 24-bit/96 kHz A/D and D/A converters and two high-performance 32/40-bit floating-point SHARC® digital signal processors for ultimate sonic resolution and 113 dB dynamic range. There are also multi-functional level meters (peak/RMS, VU and SPL meter with dBA/dBC weighting via RTA mic input) plus 64 user memories for complete setups and/or individual module configurations. You get a separate RTA mic/line input with phantom power, a professional wordclock input and MIDI connections for full remote control, preset dumps and system updates. The DEQ2496 also boasts balanced inputs and servo balanced outputs with gold-plated XLR connectors, stereo aux output, AES/EBU and S/PDIF inputs and outputs (XLR and optical). The internal switch-mode power supply assures maximum flexibility (100 - 240 V), noise-free audio, superior transient response and lowest possible power consumption. Like all Behringer products, the DEQ2496 is manufactured under ISO9000 certified management.
BrandBehringer
ModelDEQ2496
Part Number248-661
UPC689076811583
Weight7
