  • Vehicle Truck Backup Alarm Beeper 12-80 VDC 102 dB
CLEARANCE Vehicle Truck Backup Alarm Beeper 12-80 VDC 102 dB
Parts ExpressPart # 260-064
2 Questions, 15 Answers or
Increase workplace and outdoor safety around vehicles with this economical backup alarm. A 102 dB, instantly recognizable, tone emits when connected to a 12 to 80 volt DC source. Commonly connected to reverse lights on fork lifts and dump trucks, this alarm has a weather resistant housing.
  • Increases workplace safety
  • Competitively priced and extremely well built
  • High output, 102 dB tone instantly draws attention
  • Small weather resistant housing installs nearly anywhere
  • Low current consumption
We'll send you an email when Vehicle Truck Backup Alarm Beeper 12-80 VDC 102 dB is back in stock or available for preorder.
The compact size of this back up alarm makes it ideal for material handling equipment such as fork-lifts, dump trucks, tow trucks, and other vehicles. Measuring only 2-3/4" high by 4" wide by 1-5/8" deep, it is easy to locate nearly anywhere using the built-in mounting tabs. When wired to a reverse light, on 12 to 80 VDC systems, the back-up alarm emits a piercing 102 dB, industry-standard "beep-beep" reverse tone that immediately gets the attention of bystanders and workers for increased safety.
A weather-resistant housing is used to stand up to harsh work environments and the outdoor elements. Total current draw is less than half an amp, which means that you can safely add it to nearly any automotive circuit.
Specifications: • Dimensions (H x W x D): 2-3/4" x 4" x 1-5/8" • Operating voltage: 12 to 80 VDC • Current requirement: <0.5A • Output: 102 ±3 dB.
Part Number260-064
UPC848864006017
Weight0.58
