  • BOSS PT3000 Phantom 3000W High Output 2-Channel Full-Range Class A/B Amplifier
CLEARANCE BOSS PT3000 Phantom 3000W High Output 2-Channel Full-Range Class A/B Amplifier
Boss Audio SystemsPart # 265-4062
Model: PT3000
The 3000 watt max, stereo PHANTOM PT3000 high output class A/B amplifier from BOSS delivers an outstanding 3,000 watts of power to your car's sound system. Chose the PT3000 when moving door and dash speaker amplification from the head unit to a dedicated amplifier or powering subwoofers.
  • Powerful and efficient class A/B amplifier
  • 3000 watts of peak power
  • Up to 2250 watts RMS @ 4 ohms bridged
  • Red LED backlit illumination
  • Selectable high-level or low-level gold-plated RCA inputs
  • Remote volume level knob included
We'll send you an email when BOSS PT3000 Phantom 3000W High Output 2-Channel Full-Range Class A/B Amplifier is back in stock or available for preorder.
The Boss PT3000 Phantom 3000W High Output Monoblock Class A/B Amplifier delivers an outstanding 3,000 watts of power to your car's sound system. Processing such as variable low pass crossover and variable bass boost allows you to customize the sound to fit your wants.
2 Ohm Stable
The lowest impedance accepted by this amplifier is 2 ohms. Amplifiers that are 2 ohms stable produce more power resulting in more volume. This amp can comfortably power speakers or subwoofers with all channel(s) being used at a load of 2 ohms.
Class A/B Power
Class A/B amplifiers are known for their ability to produce great quality sound while performing more efficiently than pure Class A amplifiers. Boss has developed a specific linear circuitry that further reduces distortion while increasing both sound quality and power output.
MOSFET
MOSFET stands for Metal Oxide Semiconductor Field-Effect Transistor. MOSFETs are used either as a switch or to amplify a signal. MOSFETs are superior to other FETs, because they require less current to operate, which makes them better suited for car audio.
Subwoofer Level Control
The amp gives you the ability to boost or attenuate the sub level when an amp and subwoofer are connected to the subwoofer pre-amp output. Additional switchable bass boost allows you to boost low end by +18 dB. The variable low pass filter gives you control over the cutoff for the subwoofer.
Protection
If the amplifier gets too hot, the thermal protection circuit turns the amp off and allows the amp to cool down before turning it back on. If a speaker fails causing an electrical short, the protection circuit will automatically cut the output and remain in that state until the short is resolved. These safety features give you peace of mind knowing the amplifier is constantly monitoring conditions to protect itself.
Configuration: 1 channel
Topology: Monoblock, Class A/B
Total power output: 3,000 watts
Peak power (2 ohms): 1,500 watts x 2
RMS power (2 ohms): 1,125 watts x 2
Peak power (4 ohms): 750 watts x 2
RMS power (4 ohms): 563 watts x 2
Peak power (4 ohms bridged): 3,000 watts x 1
RMS power (4 ohms bridged): 2,250 watts x 1
Frequency response: 9 Hz - 50 kHz
Total Harmonic Distortion: 0.01%
Signal-to-noise ratio: 103 dB
Channel separation: 90 dB
Speaker impedance: 2-4 ohms
Inputs: 2 x RCA
Processing: Low pass filter (50-250 Hz), bass boost (0-18 db), subwoofer level control, thermal/overload/short protection
Dimensions: 22" x 10.32" x 2.25" (558mm x 261mm x 57mm)
BrandBoss Audio Systems
ModelPT3000
Part Number265-4062
UPC791489122771
Weight15.3
Input TypeRCA Line Level
Output Channels2
RMS Power Output (4 Ohms)563
