  • BOSS P69.4C PHANTOM 6" x 9" 4-Way Speaker Pair 800 Watt
CLEARANCE BOSS P69.4C PHANTOM 6" x 9" 4-Way Speaker Pair 800 Watt
Boss Audio SystemsPart # 265-3777
Model: P69.4C
Upgrade your car audio system's stock speakers with 4-way, 6" x 9" Phantom Series P69.4C speakers from BOSS. Cast baskets increase rigidity, while the frequency range is split among four speakers for increased clarity, bass, output, and power handling.
  • 4-way design for extra output, sound quality, and power handling
  • Injection-molded polypropylene woofers with rubber surrounds and cast aluminum baskets for durability
  • 40 to 20k Hz frequency response
  • Mylar cone midrange
  • Dual piezo high frequency elements
  • High sensitivity and power handling
We'll send you an email when BOSS P69.4C PHANTOM 6" x 9" 4-Way Speaker Pair 800 Watt is back in stock or available for preorder.
The P69.4C Phantom Series 4-way, 6" x 9" speaker pair from BOSS is a great way to upgrade your stock car audio speakers and transform your OEM sound system from lackluster to lively.
BOSS builds each of the Phantom Series dash, door, and deck speakers using a die-cast aluminum basket for great structural rigidity, injection-molded polypropylene woofer cone that is electroplated and attached to a rubber surround for moisture resistance, mylar cone midrange, a 1" piezo tweeter, and a 1" piezo super tweeter.
1-1/2" high-temperature aluminum woofer voice coils, combined with the use of a 4-way speaker design, increases power handling. P69.4Cs have a crisp, clear sound, and amazing bass response, that rivals many other companies' speakers at twice the price! Try a pair today and find out what all the fuss is about. Speaker wire, grilles, and mounting hardware included.
Specifications: • Power handling: 200 watts RMS/400 watts peak (each speaker) • Impedance: 4 ohms • Frequency response: 40-20,000 Hz • SPL: 95 dB 1W/1m • Dimensions: Overall: 9.5" L x 6.88" W x 4" H, Mounting depth: 3.25".
BrandBoss Audio Systems
ModelP69.4C
Part Number265-3777
UPC791489113892
Unit of MeasurePairs
Weight9.05
Speaker Size6"
Speaker Type4-Way
Power Handling (RMS)200 Watts
