  • BOSS NX654 Onyx 6-1/2" 4-Way Full-Range Speaker Pair 400W
CLEARANCE BOSS NX654 Onyx 6-1/2" 4-Way Full-Range Speaker Pair 400W
Boss Audio Systems
Part #265-4045
Boss Audio Systems
Part #265-4045
Model: NX654
The Boss NX654 Onyx 6-1/2" 4-way full range car audio speaker pair delivers a strong 400 watts (per pair) of powerful audio. Built from reliable and high-quality materials, the NX654 ensures long life of your speakers for any car application while providing an excellent sonic experience.
  • Rugged, high-quality Polyurethane cones deliver great sound while remaining durable to life on the road
  • 1" aluminum voice coil built to withstand high-temperatures while retaining strength and fatigue properties
  • Rubber surround provides reliable performance for resisting environmental factors
  • 3/4" Mylar dome tweeter allows for use without a crossover and is resistant to overloading
CLEARANCE $34.98
MSRP: $44.99
Save $10.01 (22%)
This item is no longer available
Alert Me When Available
The classic style performance of the ONYX (NX) Series are a rare combination indeed. The custom designed poly injected cones and regimented linear travel provide an accuracy of sound production transporting the exact sonic experience the artist intended in the recording studio, directly into your vehicle.
Poly Injection Cone
Polyurethane is a resilient, flexible and a durable manufactured material that allows for maximum flexibility that produces great sounding speakers lasting you a long time.
High Temperature Voice Coil
Boss speakers are capable of higher or elevated temperature strength and fatigue properties that will increase performance and efficiency of heavy duty play time through lower weight and higher operating temperatures.
Resilient Rubber Surround
Impermeable to air, rubber has the ability to endure or resist exposure to the many types of weather fronts. The surround connects the cone to the basket.
Generally, the dome tweeter is a step up from the semi-dome tweeter, primarily because of improved sound dispersion. The dome shape radiates sound with a wider dispersion pattern than the semi-dome design. Since high-frequency sound waves are directional, a wider dispersion of the sound waves will give you more flexibility to work with when setting up your system.
Type: 6-1/2" 4-way, full range
Woofer: 6-1/2" Polyurethane
Tweeter: 3/4" Mylar dome
Power handling: 400 watts RMS (per pair), 200 watts RMS (each)
Frequency response: 65-20,000 Hz
Sensitivity: 90 dB
Impedance: 4 ohms
Voice coil: 1"
Basket structure: Cast
Mounting depth: 2.25"
Dimensions: 7" x 7" x 3"
BrandBoss Audio Systems
ModelNX654
Part Number265-4045
UPC791489116213
Unit of MeasurePairs
Weight4.2
Speaker Size6.5"
Speaker Type4-Way
Power Handling (RMS)200 Watts
