  • BOSS MRGB65 6.5" 2-Way 200W Full Range Marine Speaker with RGB LEDs Pair White
CLEARANCE BOSS MRGB65 6.5" 2-Way 200W Full Range Marine Speaker with RGB LEDs Pair White
Boss Audio SystemsPart # 265-4087
Model: MRGB65
1 Question, 1 Answer or
Boss Audio's MRGB65 6.5" 2-way speaker pair Is a great way to add or upgrade the speakers in any marine audio system. These fully marinized speakers include integrated multi-color RGB with RF remote control to light up your boat, ATV, or even a backyard patio.
  • 200 watts MAX (100 watts RMS) power handling per pair
  • Integrated multicolor RGB illumination with wireless remote control
  • Polypropylene woofer cone and treated cloth surround
  • Impedance 4 ohms
  • Frequency response 70-20,000 Hz
We'll send you an email when BOSS MRGB65 6.5" 2-Way 200W Full Range Marine Speaker with RGB LEDs Pair White is back in stock or available for preorder.
Fully Marinized
Fully Marinized is the term we use for our Marine and Outdoor products that are Weather Proof. We integrate high-tech, state-of-the-art waterproofing materials plus special UV coatings for plastic surfaces, coated circuit boards and connections to protect the product against the harsh outdoor elements and resist corrosion.
Multi-color Illumination
Choose from a variety of colors and patterns while setting the speed and brightness of the built-in LED speaker lights for a dynamic, customized display. Remote control included.
Poly Injection Cone
Polypropylene is a resilient and durable manufactured material that can be used in thousands of applications across virtually all fields. In the specific case of our cones, this material allows for maximum give that produces great sounding speakers lasting you a long time.
High Temp Voice Coil
Our speakers are capable of higher or elevated temperature strength and fatigue properties that will increase performance and efficiency of heavy-duty play time through lower weight and higher operating temperatures.
Tweeter
Dome tweeters have improved sound dispersion and the shape radiates sound with a wider dispersion pattern than the semi-dome design. Since high-frequency sound waves are very directional, a wider dispersion of the sound waves will give you a larger "sweet spot" to work with when setting up your system.
Wireless Remote Control
A wireless remote control gives you commanding access to the key functions of your unit from the palm of your hand.
  • Sensitivity (1W/1m): 88dB SPL
  • Impedance: 4 Ohms
  • Mounting Depth: 2.63
  • Mounting Hole: 5.8
  • Weight: 4 Lbs
  • Dimensions ( L x H x W): 6.75 x 6.75 x 2.25
BrandBoss Audio Systems
ModelMRGB65
Part Number265-4087
UPC791489121880
Unit of MeasurePairs
Weight5.7
Speaker Size6.5"
Speaker TypeFull-Range
Power Handling (RMS)100 Watts
