  • BOSS MR1000 1000W High Output 4-Channel Full-Range Class A/B Marine Amplifier
CLEARANCE BOSS MR1000 1000W High Output 4-Channel Full-Range Class A/B Marine Amplifier
Boss Audio SystemsPart # 265-4081
Model: MR1000
The 1,000 watt max, four channel RIOT R1000 Class AB Marine amplifier from BOSS is an unbelievable value. Chose the MR1000 when upgrading the audio system in your boat.
  • BOSS RIOT Series amplifiers are some of the best values in car audio amplification
  • Much more dynamic, clear, and powerful than head unit amplification
  • 4 x 94W RMS @ 4 ohms power output
  • Class AB topology, 2-ohm stable, and fully protected
  • Clean white anodized aluminum chassis
  • Includes remote subwoofer control
We'll send you an email when BOSS MR1000 1000W High Output 4-Channel Full-Range Class A/B Marine Amplifier is back in stock or available for preorder.
If you're still using your head unit for amplification, you have no idea what you're missing! Head units are often unable to provide the loud, dynamic sound you want, and can distort (or even damage) your speakers at even medium volume levels.
That's where the BOSS RIOT Series of amplifiers comes in. Tried-and-true Class AB amplifier topology, 2-ohm stable (for powering a pair of 4-ohm speakers off a single channel), and way more than enough power for even the hungriest door, dash, or deck speaker.
BOSS built the RIOT Series amplifiers with advanced features that are usually associated with amplifiers at more than twice the price: thermal and short circuit protection, soft turn-on circuit, remote turn-on/off, nickel-plated low-level and high-level inputs, LED power and protection indicators, all housed in a clean white anodized aluminum chassis. Mounting hardware included.
Power output: 4 x 94W RMS (@ 4 ohms), 4 x 250W max (@ 2 ohms)
Frequency response: 6 to 50,000 Hz
Signal-to-ratio: 102 dB
Total harmonic distortion: 0.01% @ RMS power output
Dimensions (L x H x W): 7.375" x 2.25" x 12.75"
BrandBoss Audio Systems
ModelMR1000
Part Number265-4081
UPC791489108836
Weight8
Input TypeRCA Line Level
Output Channels4
RMS Power Output (4 Ohms)94
