  • BIC Venturi V1220 12" Powered Subwoofer 200W
CLEARANCE BIC Venturi V1220 12" Powered Subwoofer 200W
BIC AmericaPart # 303-432
Model: Venturi V1220
BIC's Venturi V1220's performance to price ratio is unmatched! Its 200 watt (430 watts peak) BASH amplifier provides more than enough power for its mated 12" heavy duty, long-throw woofer with a long-life butyl rubber surround.
  • Built-in 200W RMS (430W peak) BASH amplifier
  • Heavy duty 12" subwoofer with butyl rubber surround
  • Bass reflex cabinet with patented Venturi vent for eliminating port noise
Dayton Audio SUB-1200 12" Powered Subwoofer
Price: $179.98Part # 300-629
See all items in Powered Subwoofers
We'll send you an email when BIC Venturi V1220 12" Powered Subwoofer 200W is back in stock or available for preorder.
BIC's Venturi V1220 offers unsurpassed performance for its price! It incorporates a high current 200 watt (430 watts peak) BASH amplifier that is mated to a downward firing  12" heavy duty, long-throw woofer with a long-life butyl rubber surround. A patented Venturi vent eliminates port noise that is often heard from other lesser subwoofers when playing demanding music and video material. The V1220 also features an adjustable crossover, automatic signal sensing, high level inputs, as well as Dolby® Pro Logic, Dolby® Digital, and DTS® inputs. You can rest assured with the 7 year driver warranty and 2 year amplifier warranty.
Specifications: • Amplifier power output: 200 watts RMS/430 watts peak • Driver: Long excursion 12" subwoofer • Frequency response: 23-180 Hz • Dimensions: 18-1/2" H x 17" W x 14" D. • 90dB Sensitivity:
BrandBIC America
ModelVenturi V1220
Part Number303-432
UPC729305002587
Weight45.45
Woofer Diameter12"
