  • B25K 20K Ohms Slide Potentiometer 2" Travel with Dust Cover
CLEARANCE B25K 20K Ohms Slide Potentiometer 2" Travel with Dust Cover
Factory BuyoutsPart # 029-112
Use this 20k ohm metal stem pot to replace your current defective slide volume controls, or keep a spare around for your next vintage project. Supplies are limited.
  • Durable metal stem verses plastic
  • Dust guard keeps slide mechanism clean
  • Exact replacement for many vintage receivers and mixers
CLEARANCE $1.49
MSRP: $3.00
Save $1.51 (50%)
Only 2 In Stock
We'll send you an email when B25K 20K Ohms Slide Potentiometer 2" Travel with Dust Cover is back in stock or available for preorder.
It’s hard to find vintage metal stemmed slide volume controls. Many stereo receivers in the 70’s had these nice metal knob slide controls that you could turn the volume up and adjust the balance at the same time with one hand. This is a limited supply buyout you don’t want to miss.
Specifications: • Dimensions: 2.9” L x 0.5” W x 0.45” D without stem or terminals • Slide length: 2” • Terminal gaps: 1.84”, 2.23”, and 0.18” • Shaft length: 0.6”.
BrandFactory Buyouts
Part Number029-112
UPC848864031859
Weight0.04
Electrical CharacteristicsLogarithmic / Audio Taper
Value20K
