  • B&C ME60 2" Constant Directivity Horn 60x40 4-Bolt
B&C SpeakersPart # 294-624
Model: ME60
B&C's ME60 2" constant directivity cast aluminum horn features durable construction, tight dispersion, and very good driver loading down to 800 Hz.
  • 60&#176H x 40&#176V nominal dispersion
  • Durable cast aluminum construction
  • Constant directivity coverage pattern
Your Price: $131.76
MSRP: $219.60
Save $87.84 (40%)
We'll send you an email when B&C ME60 2" Constant Directivity Horn 60x40 4-Bolt is back in stock or available for preorder.
The B&C Speakers ME60 2" constant directivity cast aluminum horn is compact and durable. Its tight and well-controlled 60° x 40° dispersion pattern is ideal for long throw applications, or deployments that demand arrays of horizontally splayed loudspeaker enclosures. The ME60 sound character is smooth and free of distortion artifacts, and the horn flare path provides very good driver loading down to 800 Hz.
Specifications: • Nominal dispersion: 60°H x 40°V • Minimum frequency: 800 Hz • Throat diameter: 2" • Dimensions: 9.3"H x 10.6"W x 7.9"D • Cutout dimensions: 8.1"H x 9.1"W • Mounting type: Standard 4 bolt.
B&C Speakers produces a series of horns for compression drivers ranging from constant directivity models, known for their great consistency in angular coverage, to exponential models, which optimize acoustical loading and sound energy transfer. Standardized driver mounting flanges give the designer the freedom to choose the best horn/driver combination for each project.
All horns are made of cast aluminum, resulting in a robust structure that is free from resonances. The only exception to this method is the ME10; a new design that is made from precision molded plastic and incorporates stiffeners that add to its structural integrity. B&C combines advanced design techniques with critical listening tests to manufacture horns that exhibit precise pattern control, excellent driver loading, and low distortion and coloration.
BrandB&C Speakers
ModelME60
Part Number294-624
UPC844632001895
Weight4.8
ConstructionAluminum
Entry / Throat Diameter2"
Mounting Type4-Bolt
