  • B&C ME242 1.4" Line Array Horn 4-Bolt
CLEARANCE B&C ME242 1.4" Line Array Horn 4-Bolt
B&C SpeakersPart # 294-627
Model: ME242
The B&C ME242 1.4" Line Array Horn is a precision-engineered horn designed to deliver exceptional directional control and efficiency in professional sound systems. Its optimized shape and size make it an ideal component for line array applications, ensuring consistent and clear high-frequency output over long distances.
  • 1.4" throat designed for precise high-frequency projection in line array systems
  • Optimized for directional control, providing 120° max horizontal coverage
  • Compact and lightweight design enables easy integration into professional audio setups
  • Durable construction suited for rigorous use in both touring and fixed installations
  • Made in Italy
CLEARANCE $157.44
MSRP: $262.40
Save $104.96 (40%)
1 In Stock
We'll send you an email when B&C ME242 1.4" Line Array Horn 4-Bolt is back in stock or available for preorder.
The B&C ME242 1.4" Line Array Horn is engineered to deliver exceptional high-frequency dispersion with pinpoint accuracy, making it a key component in line array systems used for large-scale professional audio applications. Its 1.4" throat provides precise control over sound projection, ensuring that high frequencies are evenly distributed across wide areas, making it particularly well-suited for concerts, theaters, and other large venues.
Horizontally, the ME242 has a maximum of 120° of coverage. Vertical coverage will depend on the configuration. This horn’s optimized design allows for enhanced directional control, focusing sound exactly where it is needed while minimizing unwanted dispersion. This results in clearer, more consistent sound across long distances, even in acoustically challenging environments. Despite its compact and lightweight construction, the ME242 maintains high efficiency, reducing power loss and ensuring powerful, accurate sound without distortion.
Built with rugged materials, the ME242 is designed to withstand the demands of both touring and fixed installations. Its compatibility with a wide range of compression drivers makes it a flexible choice for system designers and audio engineers, offering versatility while ensuring top-tier performance. Whether used in a permanent installation or as part of a mobile setup, the B&C ME242 1.4" Line Array Horn provides reliable, high-quality sound projection for professional environments.
  • Throat Diameter: 36 mm (1.4 in)
  • Cutoff Frequency: 0.8 kHz
  • Design: Line Array Optimized Waveguide
  • Nominal Coverage Horizontal: 120°
  • Material: Cast Aluminum
  • Dimensions: 6.42" x 5.12" x 7.09" (163 x 130 x 180 mm)
  • Four 6.5 mm holes at 90° on 102 mm (4 in) diameter
  • Air Volume Occupied by Driver: 0.34 dm³ (0.01 ft³)
  • Baffle Cutout Dimension: 153 mm (6 in)
  • Net Weight: 0.94 kg (2.08 lbs.)
BrandB&C Speakers
ModelME242
Part Number294-627
Weight2.5
ConstructionAluminum
Entry / Throat Diameter1.4"
Exit Diameter1.4"
Mounting Type4-Bolt
