  • B&C FB464v2 2-Way 3,500 Hz Passive Crossover For DCX464-8 Coaxial Compression Driver
B&C SpeakersPart # 294-5782
Model: FB464v2
1 Question, 1 Answer or
The B&C FB464v2 2-Way 3,500 Hz Passive Crossover is designed to deliver precise signal separation, ensuring a smooth transition between drivers in high-performance audio systems. Optimized for professional environments, this crossover enhances sound clarity and balance across a wide frequency range. This two way passive crossover is made specifically to work well with the B&C DCX464 (Part # 294-6060) and DCX462 (Part # 294-6082).
  • 2-way crossover splits audio at 3,500 Hz for seamless frequency transitions
  • Optimized for accurate frequency division to maintain balanced sound quality
  • Passive design simplifies installation, requiring no external power source
  • Built with durable materials for long-lasting use in professional setups
  • Compact construction makes it easy to integrate into various speaker systems
  • Designed to work great with the B&C DCX464 (Part # 294-6060) and DCX462 (Part # 294-6082)
  • Made in Italy
Your Price: $128.16
MSRP: $213.60
Save $85.44 (40%)
We'll send you an email when B&C FB464v2 2-Way 3,500 Hz Passive Crossover For DCX464-8 Coaxial Compression Driver is back in stock or available for preorder.
Estimated back in stock 12/30/2025
The reinforced PRO version of the popular FB464, the B&C FB464v2 2-Way 3,500 Hz Passive Crossover is engineered to ensure optimal signal separation between drivers, delivering smooth transitions and maintaining sound integrity. By dividing audio signals at 3,500 Hz, this crossover allows both the woofer and tweeter to operate in their ideal frequency ranges, creating a cohesive sound experience with improved clarity and detail.
It delivers clean, distortion-free audio even under the demands of large venues and high-output environments. Its passive design eliminates the need for an external power source, simplifying installation and providing versatility for various audio applications. This crossover is also designed to work perfectly with the B&C DCX464 (Part # 294-6060) and DCX462 (Part # 294-6082)
Constructed with high-quality components, the FB464v2 is built to withstand the rigors of continuous use, ensuring long-term durability. The compact size of this crossover makes it easy to integrate into speaker systems of all sizes without compromising sound quality, offering a robust solution for engineers and audio professionals who require precise frequency management and superior audio performance.
  • Nominal Impedance: 8 Ohms
  • Filter Type: Two Way
  • Overall Dimensions: 105x137 mm (4.13x5.39 in)
  • Crossover Frequency: 3.6 kHz
  • Slope:18 - 12 dB/oct
  • Net Weight: 0.73 kg (1.61 lbs.)
  • 4 mm diameter holes on the PCB at 127 mm x 95 mm
    BrandB&C Speakers
    ModelFB464v2
    Part Number294-5782
    Weight2
