B&C FB354-8 2-Way 5,600 Hz Passive Crossover For DCX354-8 Coaxial Compression Driver
Elevate your audio system with the B&C FB354-8 2-Way 5,600 Hz Passive Crossover, designed specifically for the DCX354-8 Coaxial Compression Driver. This meticulously engineered crossover offers the most accurate point source solution, delivering flat high-fidelity response right out of the box using 100% OEM components. Ideal for pairing with the ME464 300Hz horn, the FB354 ensures flawless integration and superior sound performance.
- 2-way passive crossover tailored for the DCX354-8 coaxial compression driver
- Phase aligns mid and high-frequency elements for pristine audio quality
- Asymmetrical slope crossover at 5.6kHz for flat response and minimized distortion
- Industrial filament bulb series protection to prevent overpowering
- Compatible with ME464 300Hz horn for a cohesive system setup
We'll send you an email when B&C FB354-8 2-Way 5,600 Hz Passive Crossover For DCX354-8 Coaxial Compression Driver is back in stock or available for preorder.
