  • B&C DE95TN-8 2" Titanium Compression Driver 8 Ohm 4-Bolt
B&C SpeakersPart # 294-6072
Model: DE95TN-8
Capable of high output low distortion midrange response, the DE95TN 2" exit titanium compression driver from B&C Speakers is perfect for use in any speaker system built for extreme SPL. The 3" titanium diaphragm is optimized to deliver natural response from 500 to 18,000 Hz. The powerful ferrite motor includes a copper cap to ensure low distortion even when pushed to its limit.
  • 110 watts RMS (220 watts max) and 107.5 dB efficiency for incredible output capability
  • 3" voice coil and titanium diaphragm delivers smooth and natural response
  • Massive ferrite motor dissipates excess heat for low power compression
  • Copper shorting cap lowers inductance and minimizes distortion
Your Price: $310.14
MSRP: $516.90
Save $206.76 (40%)
Only 2 In Stock
We'll send you an email when B&C DE95TN-8 2" Titanium Compression Driver 8 Ohm 4-Bolt is back in stock or available for preorder.
Order in the next 0 hr 18 min to ship today. Details
For high output midrange response, the powerful DE95TN 2" exit compression driver from B&C Speakers will deliver unbeatable reliability and extreme SPL. A large 3" diameter titanium diaphragm and aluminum voice coil is used for low mass and maximum displacement allowing this driver to produce incredible efficiency and high power handling. The massive FEA optimized ferrite motor assembly dissipates excess heat to ensure that power compression is kept to a minimum even when driven to its limit for extended periods. In addition, the pole piece includes a large copper cap to minimize inductance improving high frequency response and keeping distortion as low as possible. The DE95TN is a powerful driver that will fit in with any high efficiency system designs.
Specifications: • Power handling: 110 watts RMS with minimum crossover of 1,000 Hz at 12 dB per octave • VCdia: 3" • Impedance: 8 ohms • Frequency response: 500-18,000 Hz • SPL: 107.5 dB 1W/1m • Dimensions: 6.7" diameter x 2.6" depth • Net weight: 9.9 lbs.
BrandB&C Speakers
ModelDE95TN-8
Part Number294-6072
UPC848864063485
Weight9.95
Diaphragm MaterialAluminum
Exit Diameter2"
Mounting Type4-Bolt
Power Handling (RMS)220 Watts
