  • B&C DE85TN-8 2" Titanium Horn Driver 8 Ohm 4-Bolt
B&C SpeakersPart # 294-613
Model: DE85TN-8
One of B&C's most popular 2" drivers, the DE85TN-8 includes a newly designed all-titanium diaphragm for increased durability and extended response.
  • 220 watt continuous program power capacity
  • 3" aluminum voice coil
  • Titanium diaphragm
  • Copper shorting cap for extended HF response
  • 107 dB sensitivity
  • 2" bolt-on format (4-bolt)
B&C DE750TN-8 2" Titanium Horn Driver 8 Ohm 4-Bolt
Price: $410.34Part # 294-615
See all items in Horn Drivers
Your Price: $285.36
MSRP: $475.60
Save $190.24 (40%)
Only 1 In Stock
We'll send you an email when B&C DE85TN-8 2" Titanium Horn Driver 8 Ohm 4-Bolt is back in stock or available for preorder.
The B&C Speakers DE85TN-8 2" titanium compression driver is an example of the transducer engineering excellence that has made this Italian company an industry benchmark. The DE85TN-8's evolution is traceable to its ubiquitous predecessors, the DE75 and DE85, found in many famous concert-level touring speaker systems. FEA-optimized ceramic ferrite magnet materials produce the driver's high flux density, and a copper cap on the DE85TN's pole piece reduces inductive losses and extends high frequency response.
Specifications: • Power handling: 110 watts RMS/220 watts program above recommended crossover of 1 kHz/12 dB slope • VCdia: 3" • Impedance: 8 ohms • Frequency response: 500-18,000 Hz • SPL: 107 dB 1W/1m • Dimensions: 6.7" diameter x 2.5" depth • Net weight: 9.9 lb. • Replacement diaphragm available.
B&C Speakers' line of compression drivers is the result of a continuous research effort, dedicated to refine every component in the structure, and their overall balance. Diaphragms are made of titanium, mylar, or polyimide, in order to get the required results in efficiency and bandwidth. Their shape and structure is mathematically evaluated well before building the first prototype. Afterwards, their performance is tested with methods that range from modal analysis to laser vibrotomy.
All voice coils are of the edgewound ribbon type, and made of aluminum to reduce mass and achieve the best electro-acoustic performance. The magnet assembly is designed and optimized with up-to-date software for Finite Element Analysis (FEA) and complemented, where needed, by a copper cap to improve frequency extension and linearity. Equal care is taken in the design of phase plugs, whose role in enhancing performance and reducing distortion artifacts is critical for compression drivers. The precision and transparency of B&C compression drivers is constantly improved by the progress in acoustical modeling and simulation.
BrandB&C Speakers
ModelDE85TN-8
Part Number294-613
UPC844632001826
Weight10.75
Diaphragm MaterialTitanium
Exit Diameter2"
Mounting Type4-Bolt
Power Handling (RMS)220 Watts
