  • B&C DE75PTN 2" Titanium Compression Driver 8 Ohm 4-Bolt
B&C SpeakersPart # 294-5828
Model: DE75PTN
B&C's DE75PTN 2" exit HF driver features an all-titanium diaphragm for increased durability and accurate response.
  • 220 watt continuous program power capacity
  • 3" aluminum voice coil
  • Titanium diaphragm
  • 2" bolt-on format (4-bolt)
Your Price: $295.80
MSRP: $493.00
Save $197.20 (40%)
Only 1 In Stock More due on 4/30/2026
We'll send you an email when B&C DE75PTN 2" Titanium Compression Driver 8 Ohm 4-Bolt is back in stock or available for preorder.
The B&C Speakers DE75PTN 2" titanium HF driver is capable of extreme output levels combined with incredible fidelity and musicality. A powerful ceramic ferrite magnet structure provides the high magnetic flux density required for the DE75PTN's high efficiency, accuracy, and extended high frequency response.
Specifications: • Power handling: 110 watts RMS/220 watts program above recommended crossover of 0.8 kHz/12 dB slope • VCdia: 3" • Impedance: 8 ohms • Frequency response: 500-18,000 Hz • Dimensions: 6.7" diameter x 2.5" depth • Net weight: 9.9 lb.
BrandB&C Speakers
ModelDE75PTN
Part Number294-5828
UPC848864009148
Weight10.35
Diaphragm MaterialTitanium
Exit Diameter2"
Mounting Type4-Bolt
Power Handling (RMS)220 Watts
