  • B&C DE400 1" Neodymium Polyimide Compression Driver 8 Ohm 2-Bolt
B&C SpeakersPart # 294-5816
Model: DE400
3 Questions, 5 Answers or
The B&C Speakers DE400 1" high frequency compression driver features a polyimide diaphragm, aluminum voice coil, and optimized neodymium magnet assembly.
  • Polyimide diaphragm
  • High sensitivity
  • Compact neodymium magnet assembly
  • Perfect for line arrays
  • 1.7" aluminum voice coil
  • 100 watts continuous program power capacity
Your Price: $157.26
MSRP: $262.10
Save $104.84 (40%)
Only 2 In Stock
We'll send you an email when B&C DE400 1" Neodymium Polyimide Compression Driver 8 Ohm 2-Bolt is back in stock or available for preorder.
The B&C Speakers DE400 1" high frequency compression driver features a polyimide diaphragm, aluminum voice coil, and optimized neodymium magnet assembly. Compact yet powerful, the neo motor's small size facilitates use in miniature speaker system designs, as well as providing a solution to the critical component spacing issues presented by line arrays. 1" horn throat diameter, 2-bolt mounting.
Specifications: • Power handling: 50 watts RMS/100 watts program above recommended crossover of 1.6 kHz/12 dB slope • VCdia: 1.7" • Impedance: 8 ohms • Frequency response: 1,000-18,000 Hz • SPL: 108.5 dB 1W/1m • Dimensions: 3.3" diameter x 1.7" depth • Net weight: 1.8 lb.
BrandB&C Speakers
ModelDE400
Part Number294-5816
UPC848864009025
Weight2
Diaphragm MaterialKapton / Polyimide
Exit Diameter1"
Mounting Type2-Bolt
Power Handling (RMS)100 Watts
