  • B&C DE250TN 1" Titanium Compression Driver 8 Ohm 2/3-Bolt
B&C SpeakersPart # 294-5814
Model: DE250TN
The B&C Speakers DE250TN 1" HF driver is a dependable and sonically accurate titanium diaphragm version of the popular B&C DE250.
  • 120 watt continuous program power capacity
  • 1.7" aluminum voice coil provides excellent power handling capabilities
  • Titanium diaphragm
  • 106 dB sensitivity
  • 1" bolt-on format (2-bolt/3-bolt)
Your Price: $147.96
MSRP: $246.60
Save $98.64 (40%)
Only 2 In Stock
We'll send you an email when B&C DE250TN 1" Titanium Compression Driver 8 Ohm 2/3-Bolt is back in stock or available for preorder.
B&C's DE250TN 1" high frequency compression driver features smooth and accurate response. Its low mass titanium diaphragm and optimized ceramic magnet assembly allow high sensitivity and low distortion up to 18 kHz. The DE250TN boasts high sensitivity (106 dB 1W/1m) and handles crossover points as low as 1,500 Hz. It is recommended for 2-way and 3-way pro audio applications such as floor monitors, compact speakers, and larger high output loudspeakers.
Specifications: • Power handling: 60 watts RMS/120 watts program above recommended crossover of 1.5 kHz/12 dB slope • VCdia: 1.7" • Impedance: 8 ohms • Frequency response: 1,000-18,000 Hz • SPL: 106 dB 1W/1m • Dimensions: 4.7" diameter x 2.4" depth • Net weight: 4.6 lb. • Replacement diaphragm available.
BrandB&C Speakers
ModelDE250TN
Part Number294-5814
UPC848864009001
Weight5
Diaphragm MaterialTitanium
Exit Diameter1"
Mounting Type2-Bolt/3-Bolt
Power Handling (RMS)120 Watts
