  • B&C DE250-16 1" Polyimide Compression Driver 16 Ohm 2/3-Bolt
B&C SpeakersPart # 294-5813
Model: DE250-16
The B&C Speakers DE250-16 1" HF driver uses its polyimide diaphragm and optimized ferrite motor to great effect. It is a durable, accurate, and great-sounding professional audio transducer.
  • 16 ohm version of one of B&C's most popular HF drivers
  • 120 watt continuous program power capacity
  • 1.7" aluminum voice coil
  • Polyimide diaphragm
  • 1" bolt-on format (2-bolt/3-bolt)
Your Price: $137.46
Save $91.64 (40%)
Only 3 In Stock
We'll send you an email when B&C DE250-16 1" Polyimide Compression Driver 16 Ohm 2/3-Bolt is back in stock or available for preorder.
B&C's DE250-16 1" high frequency compression driver features smooth and accurate response. Its low mass polyimide diaphragm and optimized ceramic magnet assembly allow high sensitivity and low distortion up to 18 kHz. Popular with professional users as well as many discriminating "high efficiency" home audio enthusiasts, the B&C Speakers DE250-16 is considered one of the most listenable high performance 1" HF drivers available.
Specifications: • Power handling: 60 watts RMS/120 watts program above recommended crossover of 1.6 kHz/12 dB slope • VCdia: 1.7" • Impedance: 16 ohms • Frequency response: 1,000-18,000 Hz • SPL: 109 dB 1W/1m • Dimensions: 4.7" diameter x 2.4" depth • Net weight: 4.6 lb. • Replacement diaphragm available.
BrandB&C Speakers
ModelDE250-16
Part Number294-5813
UPC848864008998
Weight4.85
Diaphragm MaterialKapton / Polyimide
Exit Diameter1"
Mounting Type2-Bolt/3-Bolt
Power Handling (RMS)120 Watts
Impedance16Ω
