  • B&C DE1095TN-8 2" Neodymium Horn Driver 8 Ohm 4-Bolt
B&C SpeakersPart # 294-6066
Model: DE1095TN-8
B&C's DE1095TN 2" wide bandwidth titanium compression driver delivers premium performance from 500 to 20,000 Hz. The powerful neodymium motor minimizes size and weight without sacrificing output capability. With a 4" voice coil and copper cap this driver will produce low distortion even when driven to extreme output levels.
Your Price: $520.08
Save $346.72 (40%)
We'll send you an email when B&C DE1095TN-8 2" Neodymium Horn Driver 8 Ohm 4-Bolt is back in stock or available for preorder.
Order in the next 9 hr 51 min to ship today. Details
With a 4" voice coil and huge titanium diaphragm, the DE1095TN 2" compression driver from B&C Speakers is capable of extremely wide bandwidth response and incredibly output. This state of the art driver is capable of producing 500 to 20,000 Hz with minimal unwanted resonance and natural response. The powerful neodymium motor includes a copper shorting cap to control inductance and minimize distortion even when driven to its limit. The large titanium diaphragm includes a bent edge voice coil former, improved surround, and unique dome geometry, improving rigidity for better displacement control and less deformation. Its natural response and amazing output ability makes the DE1095TN the perfect driver for large format live sounds systems and extreme mobile audio systems.
Specifications: • Power handling: 120 watts with minimum crossover of 800 Hz at 12 dB per octave • VCdia: 4" • Impedance: 8 ohms • Frequency response: 500-20,000 Hz • SPL: 108 dB 1W/1m • Dimensions: 5" diameter x 3.5" depth • Net weight: 5.29 lbs.
BrandB&C Speakers
ModelDE1095TN-8
Part Number294-6066
UPC848864063454
Weight4.9
Diaphragm MaterialTitanium
Exit Diameter2"
Mounting Type4-Bolt
Power Handling (RMS)240 Watts
Impedance8Ω
