  • B&C DCM420-8 2" Neodymium Midrange Compression Driver 8 Ohm 4-Bolt
B&C SpeakersPart # 294-585
Model: DCM4208
The B&C DCM420-8 2" Neodymium Midrange Compression Driver is designed to deliver powerful, clear midrange frequencies with outstanding efficiency. Its neodymium magnet ensures lightweight construction without sacrificing output, making it ideal for professional sound reinforcement systems where clarity and precision in the midrange are critical.
  • Neodymium magnet offers high efficiency with reduced weight for portable applications
  • Exceptional power handling for high-output performance in demanding environments
  • Advanced diaphragm design minimizes distortion for clean, accurate audio
  • Compact design makes it easy to integrate into professional audio systems
  • Robust construction ensures reliability in long-term, continuous use
  • 220 watts of continuous power handling for the high-volume environment of live sound
Your Price: $467.64
Save $311.76 (40%)
We'll send you an email when B&C DCM420-8 2" Neodymium Midrange Compression Driver 8 Ohm 4-Bolt is back in stock or available for preorder.
The B&C DCM420-8 2" Neodymium Midrange Compression Driver is engineered for delivering clear, detailed midrange audio with minimal distortion, making it an essential component in professional sound systems. Its 2" diaphragm allows it to produce precise, focused sound that enhances vocal clarity and instrument reproduction, ensuring every detail is heard in live performances, concerts, and installations.
Thanks to its neodymium magnet, the DCM420-8 offers high efficiency while maintaining a lightweight design, ideal for applications that require both portability and high-output performance. The driver is capable of handling significant power, making it suitable for use in demanding environments such as large venues and open-air events where consistent and accurate sound is crucial.
The DCM420-8’s advanced diaphragm design helps to minimize distortion, ensuring clean and accurate midrange frequencies even at higher volumes. Its compact, robust construction allows it to integrate seamlessly into various speaker systems, providing long-lasting reliability. Whether used in PA systems, stage monitors, or professional installations, the B&C DCM420-8 is a versatile driver that delivers superior midrange performance for any sound reinforcement application.
  • Power handling: 110 W Nominal, 220 W Continuous
  • Throat diameter: 2"
  • Impedance: 8 ohms
  • Frequency response: 300 Hz - 6,000 Hz
  • SPL: 112 dB
  • Overall diameter: 6"
  • Depth: 3.74"
  • Weight: 5.73 lbs.
  • 4x M6 Mounting Studs with bolts and washers included
    BrandB&C Speakers
    ModelDCM4208
    Part Number294-585
    Weight6.5
    Diaphragm MaterialKapton / Polyimide
    Exit Diameter2"
    Mounting Type4-Bolt
    Power Handling (RMS)220 Watts
    Impedance8Ω
