  • B&C 8NDL51-16 8" Professional Neodymium Woofer 16 Ohm
B&C SpeakersPart # 294-5914
Model: 8NDL51-16
2 Questions, 3 Answers or
B&C's 8NDL51-16 8" speaker offers the efficiency and smooth response of a midrange driver and combines it with the Xmax capabilities of a woofer, making it perfect for a variety of compact pro PA loudspeaker applications.
  • Great for line arrays and horn loading
  • Neodymium magnet assembly
  • Ventilated voice coil gap for reduced power compression
  • Inductance-reducing copper cap on pole piece extends HF response
  • 2" copper voice coil on polyimide former
  • 400 watts continuous program power capacity
  • 65 – 3,000 Hz response
Your Price: $150.30
MSRP: $250.50
Save $100.20 (40%)
Out of Stock
We'll send you an email when B&C 8NDL51-16 8" Professional Neodymium Woofer 16 Ohm is back in stock or available for preorder.
Ships in 7-10 Business Days
The B&C Speakers 8NDL51-16 is an efficient and lightweight cast frame 8" neodymium driver. Its ventilated voice coil gap ensures long term power handling and reduced power compression, and a copper cap on the pole piece reduces inductance and extends high frequency response. The 8NDL51-16 is highly recommended for compact 2-way speaker systems or as the midbass/midrange element in high-output 3-way and 4-way designs.
BrandB&C Speakers
Model8NDL51-16
Part Number294-5914
UPC848864009476
Weight5.05
Nominal Diameter8"
Bolt Circle Diameter8.3
Power Handling (RMS)400 Watts
Impedance16Ω
Frequency Response70 to 3,000Hz
Sensitivity94dB 2.83V/1m
Voice Coil Diameter2"
Resonant Frequency (Fs)70Hz
DC Resistance (Re)10.6Ω
Voice Coil Inductance (Le)0.6mH
Mechanical Q (Qms)5.88
Electromagnetic Q (Qes)0.51
Total Q (Qts)0.47
Compliance Equivalent Volume (Vas)0.47ft³
BL Product (BL)15.2T·m
Diaphragm Mass Inc. Airload (Mms)26g
Maximum Linear Excursion (Xmax)7mm
Surface Area of Cone (Sd)220cm²
Cone MaterialCoated Paper
Surround MaterialCloth
Voice Coil FormerFiberglass
Magnet MaterialNeodymium
Overall Outside Diameter8.8"
Baffle Cutout Diameter7.4"
Depth3.5"
Sealed Volume0.3ft³
Sealed F3117.8Hz
Vented Volume0.63ft³
Vented F362.5Hz
